Old 10-11-2011, 01:44 PM
patrickt patrickt is offline
Default You Can Do it, Really.
Originally Posted by Tony Radford View Post
I'm thinking at this point that the best recourse for me is to pull it and take it to a shop that specializes in alternators.
Tony, seriously, there is nothing to it. You can do a first-rate job in under a half hour sitting at the kitchen table. It's completely intuitive, and goes back together exactly like it came apart -- and nothing comes "flying apart" when you take the back off. The only trick, and it's not much of a trick at all, is holding the brushes back with a little wire when you put it back together and then you yank the wire. Give it a try, if you find you're stumped just take the alternator in and tell them you started the job and got discouraged. But I'm 99% sure that won't happen. The rebuild kit even comes with instructions (which you really don't need but are always nice to have).
EDIT -- And the little wire to hold the brushes back comes in the kit, too.
