Old 10-17-2011, 12:01 PM
Tommy's Avatar
Tommy Tommy is offline
Originally Posted by BlueRooster View Post
Note to self: Don't leave the key in run position.
A bit of trivia in case you didn't already know this. Cars built with mechanical points back before electronic ignitions had both ballast resistors AND ignition switches with one or more switch positions than modern cars. For example, my 1963 Corvette ignition switch has (from left to right): Accessories, Lock, Off, Run, Start. The Accessories position was to allow all electrical systems except the ignition to be powered. This was specifically intended to prevent overheating the ignition system components and burning the points if they happened to be closed when the operator wanted to sit and listen to the radio. Modern cars generally don't have the Accessories position because modern electronic ignitions don't have that problem. The fact that your car has a ballast resistor tells me you should either have an ignition switch with an Accessories position, or you should remember your note to self. .... BTW, most cars are wired to allow the headlights to operate without having the key on.
Tommy
Previously owned EM Cobra
