Thread: 351 Distributor
  #34 (permalink)
Old 10-17-2011, 02:00 PM
Ant Ant is offline
Default 351 Distributor
Spoke to Performance Distributors,
They said they can do a Cleveland Duraspark Distributor with a Windsor gear. Their Cleveland distributor is 1-1/2" lower profile than the Windsor.
Not sure on what advance is needed as they require you to fill out a spec sheet of camshaft specs, weight of car etc As I will be running the ICE ignition box which has about 80 advance curves to choose from e.g. starting from range 1150 -1450 and finishing range 2900-3800.
A J. Newton
The 1960's rocked!
