Thread: 351 Distributor
  #35 (permalink)
Old 10-17-2011, 03:41 PM
Ant Ant is offline
Default 351 Distributor
Latest update, spoke to Distributor supplier, he told me a Ford Duraspark distributor isn't compatible with his ignition. He is going to cut the distributor shaft below the housing, make up a sleeve to adapt the larger shaft with drive gear to small shaft, then pin each shaft to sleeve.
A J. Newton
The 1960's rocked!
