10-18-2011, 11:31 AM
AZ
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
I'd look at the metering blocks on the Carb. The coating gets pretty funky after a while. Just pull one off at a time. It's pretty obvious if that's the problem once you look. The passages get plugged up. Clean and scrape off the chunks carefully or replace the blocks if needed.
