Thread: ISIS Group Buy!
Old 10-19-2011, 05:28 PM
Xack's Avatar
Xack Xack is offline
Cobra Make, Engine: West Coast Dreams
Default Yes, but No.....
ISIS Power is a wiring system. It's a computer with modular inputs and outputs. The inputs wire to your dash switches. The beauty is that there is the low voltage on the inputs. 5 volts on the input to ground enables the corresponding output (ex. Lights). The dash can be wired with small wiring and ther is no danger of short circuit fire under your dash. Alarm system is integrated so it saves battery power.
The outputs wire directly to the lights, ignition, radio power, anything that will draw less than 10 Amps or so. Anything else higher amp draw you connect to a relay and fuse externally.
Why would you use such a system?
1. modular, reduces wiring, some... uncomplicates wires under the dash.
2. computer control contains functions like flashers, turn signal, Push to start ignition switch, integrated brake/turn signal, etc. If you need a custom function you can call and get them to program it into your system.
3. Ouput wiring is simple and direct to the device. Headlights, turn signal, Brake lights,
4. integrated alarm/locks/anti-theft system.
5. Control items like interior lights, trunk lights, Headlights, door/trunk popers from Key FOB. or your smartphone or iPad computer
6. The dash controls can be on a touch screen interface on the dash with no wiring at all.
