Old 10-20-2011, 07:33 AM
Doubledip's Avatar
Doubledip Doubledip is offline
Send a message via ICQ to Doubledip
Originally Posted by Zedn View Post
Double Dip, the hole is about 5mm. In you experience do you think it will make much difference to the idle?
the idle will be fairly high with this hole...
so you have a Brass bladed throttle body... make sure you have the correct ecu for it then..otherwise you will have problems
they drill holes in them to get the engine to idle at a decent speed when a big cam is inserted...
www.ultimateconversionwiring.com.au
_
