Old 10-20-2011, 06:39 PM
james911pro's Avatar
james911pro james911pro is offline
Cobra Make, Engine: SPF Roush 427R
Originally Posted by SwiftDB4 View Post
I've had oil burning issues on my 427SR, but not as bad as some of the posters. The MSD ignition cap had broken the center electrode off and I didn't find this until the engine had 3000 miles on it. I assume fuel wash may have affected ring seal, but I do get compression readings of 170-185psi. Since changing the MSD cap and going to a QF carb with leaner idle and main jets, oil on the spark plug threads is virtually gone. The engine now has about 10,000 miles and burns 1qt./1200 miles. Otherwise it performs well. Is the oil consumption to be expected for these Roush stroker engines?
Swift, I never thought of that but when my dealer changed the plugs after the carb was replaced by roush the all seemed to have the same bad carbon build up. None worse than the others. But I might check into them jsut in case. From what I heard here and about Roush engines 1pt per 1000miles seems "normal".
