Thread: Flywheel choice
Old 10-21-2011, 09:24 AM
Default Any chance of seeing a picture of the damage?
Flipscobra Any picture of the damage. Does your bellhousing have a block plate? What kind of starter do you have? If you are running a mini starter without trimming the block plate you will have only about 1/2 or 3/4 complete contact of the stater gear to the fly wheel. I had this problem with a mini starter. Something to check. Some guys machined the starter housing down .060" to help with engagement. If the flywheel was balanced with the motor, repair it, shop araound and compare repair against replacement of the flywheel. What condition is it in?? Rick L.
