Old 10-23-2011, 08:43 PM
Cobrajames's Avatar
Cobrajames Cobrajames is offline
Cobra Make, Engine: SPF 2303, Titanium Silver, Roush 427 SR/TW, AED Carb, Firefly Sides, TKO 600
Default Help, Gauge Issue.
My SPF is #2303 and both my Oil Temp. and my Water Temp. Gauges stopped working at the same time 1 week ago. My turn signals stopped working at approx. the same time and I found the flasher cover damaged and shorting out on the metal clip that holds it in place. I have temporarily repaired the flasher while waiting for a new part and my turn signals now work. Everything else seems to be working properly and I have visually checked all fuses under the dash. Is there something else that could be damaged in the fuse box drop panel area that could be causing both gauges to stop working? Can anyone point me in the right direction before I start pulling things apart to test wires and gauges?
Thanks for your help,
James
