Old 10-24-2011, 06:59 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
The shafts were not bad at all. I just think the dove rockers were not the correct fit for my motor, cam, spring pressures.
I dissected the hell out of those rockers dove said it was the push rod length, everything except there rockers were the problem. The dove rockers are good if you running 350 - 400 lbs of pressure (from what I am told). It was recommended to spend the money and get a set that would handle the pressures that my springs were given. So I measured up the push rods several times to make sure it was correct and 1000 miles later no issues.
