Old 10-24-2011, 09:52 PM
Buzz's Avatar
Buzz Buzz is offline
Originally Posted by ZOERA-SC7XX View Post
For street use, I'd leave the rear sway bar off. What it does is keep more weight on the inside rear wheel with high-speed tight cornering (almost the same effect as higher rated rear springs), preventing weight transfer and making the rear end loose, something you don't want in a Cobra. It's great with soft rear springs and smooth roads, or on a high-speed race track with race tires, but may not be too desireable with standard or stiff rear springs on normal roads. Remember those old films with Ken Miles driving the Shelby Cobras on the track with lots of body roll? He didn't use a rear sway bar. He let the chassis do its job.
With that said, every Cobra is different and every driver has their own preferences, and with all the different chassis setups available, there's no hard rule, but just because you have a rear sway bar doesn't mean you'll have a better handling Cobra. Less is more.
Words of wisdom right there. Depending on the type of driving you do and what roads you do it on, stiffening up the suspension to remove all traces of independent articulation and body roll may not necessarily be the most satisfying way to go.
Tropical Buzz
