Old 10-26-2011, 04:43 AM
DAVID GAGNARD's Avatar
Originally Posted by Zedn View Post
Yeah, i have found that you need a good water trap and to pull it all apart for a clean every 20mins or so.
David, With the sand, i have used it like that too. Problem is moisture but putting an oxy on it and shoveling around in a wheel barrow dries it out. Doesnt make it safe though. Wear a mask.
I do wear a mask.....I started out using beads,but most of the things I blast are heavier metal items with a lot of rust on them and beads just take too long and in a lot of cases will not cut thru the heavy rust, sand is just easier and faster...
For smaller,"delicate" items, I use the beads.....
David
DAVID GAGNARD
