Old 10-26-2011, 04:55 AM
strictlypersonl strictlypersonl is offline
Originally Posted by ZOERA-SC7XX View Post
You might have the wire plugs reversed. Try changing them.
You can check whether things are correct on the light:
Disconnect both wires from the light (making sure that the wires don't ground out).
Turn the parking lights on.
Touch the red wire to each terminal. One will light up brighter than the other. That's the terminal to correct the other wire (yellow or green).
