Old 10-27-2011, 03:56 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
For my car I have a C&R aluminum Nascar type radiator with the oil cooler in one end tank---It is a double pass crossflow rad that goes across one half then down the oil heat exchanger and then back across the bottom half----I use the word heat exchanger because I believe that the rad will heat the oil to the temp it needs more than cooling it--
