Thread: 351 Distributor
Old 10-27-2011, 06:09 PM
Ant Ant is offline
Default 351 distributor
I have come up with an idea buy a Duraspark from Performance Distributors get the advance setup for my application then remove the advance mechanism so that it can be used with an MSD, Crane box etc for an alternative system option.
Then lock the dist for use with the Ice ignition box (not sure if I need anther advance mechanism to do that) now as the Durasparks (MSD) magnetic pickup isn't compatible with the Ice box, use the distributor as a crank trigger distributor and buy a Moroso crank trigger and that way I use the Duraspark distributor and have all the benefits of the Ice programmable box.
The Moroso bracketry won't be compatible with my engine due to dry sump pump on RHS engine, would have to fabricate bracket and sort timing out.
A J. Newton
The 1960's rocked!
