  #23 (permalink)
Old 10-28-2011, 04:50 AM
Caprimaniac's Avatar
Caprimaniac Caprimaniac is offline
Cobra Make, Engine: Unfortunataly ; none
Hi.
Yeah, Gaz- that's the Jenvey 30mm's.
The injector angle is fixed on the bodies. The picture of the manifold has some distortion, and the angles are not 100% correct. I have tried to extrapolate to put the bodies on the manifold as they will be in the real world.
Therefore, I cannot alter the direction of spray. And that is one of the concerns....!
But let's have a look at another drawing. This is the Inglese IDF manifold with throttle bodies. This is even worse, yes?
I do have the possibility, though, to buy an IDF maniolfd and bolt on the reverse plates..... Is there someone who've tried this on the 302 and found enough room between the TB's for fuel rails????
RS
