Old 10-28-2011, 09:53 AM
Tony Ripepi's Avatar
Tony Ripepi Tony Ripepi is offline
Cobra Make, Engine: TBD
Default SPF Clutch/Pressure Plate RR
Hello All,
I have a ten year old SPF in the garage that needs a new Clutch and pressure plate. Engine is a 392 windsor and a Tremec TKO transmission.
Can the RR be done from under the car?
I have it on the lift and it looks like there is plenty of room to take out the drive shaft, starter, slide the transmission back, disconnect the shifter and boot from the top, remove the bell housing and gain access for the new bits.
The current slave is an internal inline unit, does it need to be rebuilt/replaced ?
Should I convert it to an external slave/fork mechanism?
If I convert which vendor supplies the best unit?
Any and all comments/advice are welcome.
Tony R.
