Thread: S/O or ?
Old 10-30-2011, 03:56 PM
Default A good machinist can convert it to SO
hkmp5 Mike if the price is right and it passes sonic test BUY IT. You can always sell it down the road. The other thought is that this motor can be converted over to a side oiling with a good machinist. All you need is to have the bottom side oil channel drilled out. Forget the pressure spring at the back of the block and use the pressure control in the oil pump. It will do the same thing just a different location. Most the work is alway done. Just a thought. Rick L.
