Old 10-31-2011, 02:33 AM
WKB's Avatar
WKB WKB is offline
Cobra Make, Engine: Harrison Cobra, SC540 Roadster
Default Stability Control
Can any electonic guru explain in detail how the the stability control works, ideally in a BF Falcon, but if not any late model system eg how the steering sensor works in conjunction with direction of the car and the influence on the abs controller.
I had all the fault codes cleared and/or reset in the 540 today and as well the steering position senor calibrated. Now the stability control starts to activate at speed going around some corners. I know of another 540 with stability control doing something similar.
I have got to try to work out why it does and can it be fixed. I am thinking the shorter wheelbase compared to the falcon could be the cause, but I need to understand how the system works.
Warren
