Old 10-31-2011, 03:53 AM
Default A note to the Wise
Guys these Led light are nice but Do have problems just like HID headlights. Some bulb make alot of heat in an enclosed small area and have no outside air to swap with hot inside air. I have seen wiring harnesses, sockets, and lens melted from installing lights that are either too bright or too hot in a tail light or head light housing. Those deflectors should be a Heads UP on the amount of heat these little lights make. If wired right should be able to see them in the day light. Other note while a 3rd brake light look silly on a cobra, it might save your life or whiplash from a rearend accident. Polished Kirkhams are the oNLY car you don't have a problem not seeing any time. Rick L.
