Old 11-02-2011, 09:52 AM
bliss's Avatar
bliss bliss is offline
Originally Posted by Clayboy View Post
Bliss,
If you are looking for a inexpensive homemade lift that works well, disassembles and stores easily... look in my gallery. Mine uses engineered floor truss material and plywood. It is internally braced and is stout as ....! All pieces are glued with construction adhesive and screwed together with deck screws, did I mention it is also very stout! It is based on another homemade lift designed and built by former CC'er Red Barchetta. For detailed photos of Red's setup go to www.cobraregistry.com - anything cobra and view his photos and description of the construction.
Bob
Your unit is awesome, but unfortunately I've no skills in that area. Race Ramps sells a unit called "portable pit stop" made with foam parts for around $2,600 that looks and works just like the one you built probably for a lot less. For that amount of money, I'd go with MaxJax as recommended here. But, something along the lines of your set up would work fine. Perhaps I can find someone to build one for me. Lifting the car up and being able to remove the center pieces of a ramp seems like a good solution for a home garage environment.
By the way, I live only 50 miles from you!
