Old 11-02-2011, 11:48 AM
Zaphod B Zaphod B is offline
Cobra Make, Engine: Not yet!
Originally Posted by bliss View Post
Your unit is awesome, but unfortunately I've no skills in that area. Race Ramps sells a unit called "portable pit stop" made with foam parts for around $2,600 that looks and works just like the one you built probably for a lot less. For that amount of money, I'd go with MaxJax as recommended here. But, something along the lines of your set up would work fine. Perhaps I can find someone to build one for me. Lifting the car up and being able to remove the center pieces of a ramp seems like a good solution for a home garage environment.
By the way, I live only 50 miles from you!
Bliss, if you don't have the carpentry skillz, find a local carpenter. Should be an afternoon's work.
