Old 11-04-2011, 10:33 AM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
The issue isn't so much appearance, it's the elevation of the "elbow" being higher than the fill cap on the expansion tank:
Originally Posted by Cashburn View Post
Expansion tank appears to not be at highest point of cooling system?
I think you need to worry about air pockets interfering with coolant flow...I might be wrong, but most engines need an air-bleed at the highest point in the cooling system, which is usually the radiator cap on the radiator. On my Cobra there's a radiator cap fitting inserted into the upper radiator hose (I have no expansion tank, but do have an "overflow reservoir" mounted on the inner fender wall, much like a production car). On my car, the radiator cap is clearly at the highest point in the system.
Cheers!
Dugly
YD,E./PNB
No names were changed to protect the innocent!
Last edited by YerDugliness; 11-04-2011 at 10:40 AM.. Reason: added quote from Cashburn
