Old 11-04-2011, 01:29 PM
Cashburn's Avatar
Cashburn Cashburn is offline
Backdraft Racing Dealer
Originally Posted by YerDugliness View Post
The issue isn't so much appearance, it's the elevation of the "elbow" being higher than the fill cap on the expansion tank:
I think you need to worry about air pockets interfering with coolant flow...I might be wrong, but most engines need an air-bleed at the highest point in the cooling system, which is usually the radiator cap on the radiator. On my Cobra there's a radiator cap fitting inserted into the upper radiator hose (I have no expansion tank, but do have an "overflow reservoir" mounted on the inner fender wall, much like a production car). On my car, the radiator cap is clearly at the highest point in the system.
Cheers!
Dugly
The cap is on the top of the tank, the tank is below the crazy AN elbow AND the heater core...
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
