Old 11-04-2011, 04:58 PM
Rawkkrawler's Avatar
Rawkkrawler Rawkkrawler is offline
Cobra Make, Engine: Everett Morrison
Default Clutch Pedal Fade
Not sure what to do next....
I'm using a floor mounted Wilwood 1" bore master with a hard line to a push type slave (not sure of the brand). I do have the Wilwood 2lb residual valve in line as well.
When driving, the clutch seems to need two to three pumps to get a good pedal. If I lift off the pedal (sort of a snap motion) the pedal loses 50% of it's feel. If I do it twice it's almost gone.
I then have to pump it two to three times to get it back. If I rest my foot lightly on the pedal, it seems to be better for some reason. Almost seems like it needs a little preload, but that doesn't make sense.
No fluid is leaking out at all and the MC was bench bled.
Any thoughts?
Mike D
Tampa Fl
