Old 11-04-2011, 06:46 PM
GoMangoMan's Avatar
GoMangoMan GoMangoMan is offline
Cobra Make, Engine: Shell Valley Classic Wheels #20117
I'm confused. I am 1500 miles away from the build. The heater core is behind the dashboard and is going through the firewall ... correct? The overflow tank is in the same position (if not higher) than that of the BDR engine bays that I have seen. The AN elbow seems high but I don't know. Can you explain or recommend how it should be (including parts)? I know it's a lot to ask but, again I am not there where it's being built. I will need to pass the info along. Thanks.
Regards, Rob
