Old 11-04-2011, 07:38 PM
Rawkkrawler's Avatar
Rawkkrawler Rawkkrawler is offline
Cobra Make, Engine: Everett Morrison
MC is brand new.
Simple unit with a built in large resevoir.
Floor mounted. Slave is about 8" above MC.
Brakes had a similar issue. I was using a hand operated vacuum pump at each bleeder then moved to a air operated vacuum bleeder with no luck. The old fashioned two person forced out the remaing air and the brake now feels good.
I tried the same method to the clutch but didn't get the results as the brakes.
Mike D
Tampa Fl
