Old 11-08-2011, 09:17 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Neutral
My understanding of the process is a follows:
The PCV valve is the path to remove condensation (which is a product of combustion) from an engine as it gets warm, A cooling system temp of 185F to 195F (85C - 91c) is requires to vaporize moisture from the oil. Accumulated fuel in the oil is vaporized at a lower temperature. Under normal conditions, oil temperature is usually 15-25 degress hotter then the coolant temperature. Oil oxidizes at temperatures above 250F causing varnish deposits. The ideal temp for oil is 195F (91C) (Note: Water boils at 212F or 100C)
SPFWiringDiagrams@Comcast.net
