Old 11-11-2011, 12:59 PM
Cashburn's Avatar
Cashburn Cashburn is offline
Backdraft Racing Dealer
Know what Cashburn?
First off- I apologize for the personal insult to your (I think) screen name. Was out of line.
To be clear, I didn't single you out as a Roush dealer to dump on you. You just happen to be the only one of those that tried to explain/defend the Roush system.
Which also says something.
Let's agree to disagree. You continue your business and I'll continue to encourage non-builders to research power choices and their origins much more carefully.
Having said that, there were no falsehoods in any of my quote. A local SPF assembler allowed about 40 of us (Cobras) to coffee and chat at his shop weekly and I saw pallet after pallet of R's on the floor with the manila tags on the distributor.
Further, I used to market and write all tech for a HP crate engine outfit that used only their own castings.
427 Windsor: 525 HP: solid cam: pump gas:$10,295.
460 Windsor: 600 HP: roller cam: pump gas: $12,195
427 Windsor DRAG 630 HP: solid roller: race gas: $10,995
Aluminum blocks were a $2500 option. Could get the whole thing polished for $1300 more. Oh and Accel DFI was a $3500 option. Still not near any Roush numbers, am I?
Those were always conservative HP numbers 'cause if you sent one out that made 599HP instead of 600 they'd send it back *****ing.
They routinely made 540, 620 and between 680 and 718 HP respectively.
They went to the customer needing a water pump and fuel pump only. Warrantied 2 years.
So I didn't lie and I know what parts cost from the build sheets which I compiled and advertised.
Let's live to fight another day.
To be clear, the title Cashburn came from the simple fact that when we started in this business (and for me in particular) we basically lit the money on fire to get started and continue to burn it the whole way. If it was solely about the check we would have already checked out.
Yeah the engines arrive with a tag, and then in the mail with your warranty packet comes the actual dyno chart with serial number etc. In that same packet you fill out you see it's not an insurance company warranty, it's all done in house (at Roush). There's also a form to get you plate back with your engine serial number etc. on it (that will only have value to some, but it has value).
It sounds like you did marketing for World Industries. We considered their engines for 15 minutes and then started adding in all the components those prices did not include (no waterpump means no pulleys, belt, brackets, alternator, thermostat, water neck, it goes on and on) and suddenly we are at a price within 1-1.5k of the Roush price (but you still have to get all those other parts and make sure they lineup and fit etc.). Then you consider dyno claims and how they are tested, correction factor used, etc. and is the dyno number for your engine of the test engine etc.
Your prices also ignore inflation. But you can get the full polished option on the Roush for 1,200 today!
I'm not arguing, I'm stating my experience in the industry and having to put our name above the engine builder's name AND the chassis manufacturer's name.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
