Old 02-12-2002, 08:51 AM
CobraEd's Avatar
CobraEd CobraEd is offline
Default Sad but Probably True
Start with a cage containing five monkeys.
Inside the cage, hang a banana on a string and place a set of stairs under it.
Before long, a monkey will go to the stairs and start to climb towards the banana.
As soon as he touches the stairs, spray all of the other monkeys with cold water.
After a while, another monkey makes an attempt with the same result, all the other
monkeys are sprayed with cold water. Pretty soon, when another monkey tries to
climb the stairs, the other monkeys will try to prevent it.
Now, Take away the cold water.
Remove one monkey from the cage and replace it with a new one. The new
monkey sees the banana and wants to climb the stairs. To his surprise
and horror, all of the other monkeys attack him. After another attempt and
attack, he knows that if he tries to climb the stairs, he will be assaulted.
Next, remove another of the original five monkeys and replace it with a
new one. The newcomer goes to the stairs and is attacked. The previous
newcomer takes part in the punishment with enthusiasm! Likewise, replace a
third original monkey with a new one, then a fourth, and then the fifth.
Every time the newest monkey takes to the stairs, he is attacked. Most of
themonkeys that are beating him have no idea why they were not permitted to
climb the stairs or why they are participating in the beating of the newest
monkey. After replacing all the original monkeys, none of the remaining
monkeys have ever been sprayed with cold water. Nevertheless, no monkey
ever again approaches the stairs to try for the banana.
Why not.......... Because as far as they know that's the way it's always been done.
And that is how company policy begins.
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
