Old 11-17-2011, 06:55 PM
LMH's Avatar
LMH LMH is offline
Originally Posted by elmariachi View Post
Excellent stuff Russ, especially the IRS conversion info. Would it be possible to convert a car that already had the rear trunk tub mounted?
FYI I have POR-15 on my frame and it absolutely sucks as a final coat. It looks terrible over time, it is soft and subject to being knocked off with the slightest contact and it sure as hell doesn't stop rust. Even if everything that could go wrong did go wrong the day my frame was coated (back in 2008 by the prior Hurricane company) the stuff should still not act like this. I only say this because it would be well worth the effort to go ahead and topcoat it now.
Jim
Hey Jim
When I bought mine, Hurricane was fitting Dean Lampe's original Hurricane with the IRS unit for testing. It was originally a 9" but was switched after completed. I'm sure it would be do-able to switch yours now if you wanted.
Alba gu brąth
