Old 11-17-2011, 08:08 PM
elmariachi elmariachi is offline
Originally Posted by LMH View Post
Hey Jim, When I bought mine, Hurricane was fitting Dean Lampe's original Hurricane with the IRS unit for testing. It was originally a 9" but was switched after completed. I'm sure it would be do-able to switch yours now if you wanted. Larry
Thanks Larry, as I look at the cage it would appear that as with Russ, just chop the pan hard and 4-link mounts and then its a weld-in.
Russ, I have have had my car inspected at the local Jiffy Lube since I built it. They have never checked the tires and this last year they didn't even ask to hear the horn or see the wipers (though both worked fine.) I also didn't let them drive it for the brake check, I drove them through the test. This last time they were so enamored with the car, they just stickered it, took my $14.50 and said "Light 'em up when you leave." Okay.
