Thread: New Years Day
  #22 (permalink)
Old 11-17-2011, 10:21 PM
RedSnake351's Avatar
RedSnake351 RedSnake351 is offline
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
THANK YOU, JEFF!!!
Now, explain THAT to Mikie. I know what I'm drinking but apparently Mikie's mind must be clouded from the rich exhaust fumes he's inhaled while going up to Yarnell Hill!
Read this, Mikie, then tell me again who's playing with his...
Oxygen tends to settle to low places, due to atomic weight molecular theories and gravity. Oxygen levels found at 5,000 ft. are a full 16% less than levels found at sea-level. At 10,000 ft. this percentage loss of oxygen now approaches 30%. As carburetor jets remain fixed, the diminished oxygen in the thin mountain air will burn poorly with the carb's fixed amounts of fuel. The logical outcome is black smoke from the tailpipe, and poor mileage, and significantly reduced power outputs.
Phoenix elevation is 1115 ft.
At 1115ft, the standard barometric pressure is 97 kPa (731 mmHg). This means that there is 96% of the oxygen available at sea level.
Yarnell elevation is 4777ft.
At 4777ft, the standard barometric pressure is 86 kPa (644 mmHg). This means that there is 85% of the oxygen available at sea level.
So, there is 11% LESS oxygen at Yarnell than in Phoenix, there IS definitely a difference how your carbureted engine runs!!!
Ralphie, who sometimes knows what he's talking about!
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
