Thread: Inglese
Old 11-19-2011, 04:58 AM
Caprimaniac's Avatar
Caprimaniac Caprimaniac is offline
Cobra Make, Engine: Unfortunataly ; none
Stephan & all... I've decided a XFI injection system for my 347 (8- stack or 4- barrel; I've not settled yet!) and I've been using the resources at Comps tech forum alot. Go here for XFI tech forum: FAST Product Support - CPG Nation Forum
You will also find tech articles, news, updates etc. here.
To be honest I have to say that the Inglese and Fast XFI catalogues/ tech info is rather disapointing. Here's the list of information I have not found in the catalogues/ tech pages:
Diameter of distributor shaft (to get other gear types)
Bolt diameter on stack flange on 8- stack 50mm IDA TB's (as I think the cost of 440$ for a set of stacks is rather steep)
Distance between the ends of the fuel rail (to figue if a U aluminum tubing can be used)
If the appropiate fuelrail fittings are included and what's the AN size of the fuel in/fuel out? (to plan regulator setup & parts needed)
Thank you
Regards
RuneS
