Old 11-20-2011, 12:35 AM
Default If you re looking for more power
Cashburn Jay If you are looking for more power with getting crazy Look at the Snow water mister system. You can run a 50/50 of water alcohol raise the timing, lower combustion temps and pickup another 40-50 HP and 30-40 FT of torque with only timing and jet change. An A/F meter would be hiden for checking the setup at cruise to not have a lean out. The other thing is blower bang, Don't run the motor at WOT and then shut down the throttle to idle. Does the blower have a small blow up valve? If so then you are all right. Heat is not your friend. Adding a couple of small blowers to the fender ducts will help remove some of it to cool down under the hood. Nice setup Good luck Rick L.
