Old 11-21-2011, 05:40 PM
DRAGON's Avatar
DRAGON DRAGON is offline
Cobra Make, Engine: Factory 5
This is the writeup of my engine that came with the car.
It is a built 302 bored .020 over and makes a dyno tested 331hp at 5900 rpm and 324ft./lb. of torque at 4500 rpm. The machined block is equipped with a balanced rotating assembly complete with SRP forged flat top pistons and shot peened connecting rods. Next, a Comp Cams XE274HR camshaft and Air Flow Research 185cc aluminum heads with Comp Cams roller rockers were bolted up. Then an Edelbrock Performer RPM intake topped with a Holley Street Avenger carburetor finished things off. An MSD ignition system complete with both an MSD distributor and MSD coil provides the spark.
The trouble with retirement is that I never get a day off!
