Old 11-22-2011, 08:25 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Absolutly. If the tire is on the correct rim width, it will maintain a flat contact patch through a wider range of pressures. Since pressure changes with temps, you'll get better performance throughout the temp range. Differant tires of the same size have differant requirements, so check the manufacturers info about that.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
