Old 11-22-2011, 01:51 PM
RestoCreations's Avatar
RestoCreations RestoCreations is offline
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Its just a straight through pipe with packing material around it. It really isnt restrictive at all. I guess my fuzzy pictures is showing the wrong thing. Look at the picture of the pipe on the ground. At the front of the pipe is the collector that i removed and next to the sidepipe is the mesh tube that inserts into the stainless pipe. It simply slides down inside of the stainless steel pipe and has sound dampening material around it. The mesh pipe appeared to be around 2-1/4 to 2-1/2 in diameter and is straight through. The design gives the exhaust a nice low rumble, but it still loud and does get very loud under full acceleration, but it is not like some of the glasspacks that are in my opinion obnoxious and will make you want to rip your ears off. Also, the mesh does not produce a flappy sound at idle while cruising, it keeps that nice low pitch. However, it does flap when backpressure is present, but it isnt terrible.
