Old 11-22-2011, 12:59 PM
mreid's Avatar
mreid mreid is offline
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
Electrolysis occurs when your coolant becomes acidic. Now you have a big battery with metal removed from one surface (typically your aluminum components) and deposited on another. Zincs are designed to be sacrificial, which assumes that electrolysis is present. If you don't want to eliminate the threat, I guess a zinc anode is a solution, but the correct solution is to eliminate the electrolysis. You do this through a good antifreeze with regular maintenance of your cooling system.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
