Old 11-22-2011, 05:45 PM
cobred's Avatar
cobred cobred is offline
Cobra Make, Engine: ERA #698 428 Toploader
Looking at the bottom picture the rotor is probably only stuck on with a little rust around the axle flange. Give the rotor a few hits with a large hammer, between the studs where the wheel sits (not on the brake pad surface). It should pop off. You do have to remove the axles and then the center section (pumpkin) will come out.
