Old 11-23-2011, 07:17 AM
KirkV KirkV is offline
Cobra Make, Engine: Superformance #678
I am only pulling the main flange on the differential not messing with the front pinion flange or shaft. Shouldn't I be able to pull the axles and drop the main body with no worries? Also the washers were there for the emergency brake mount assembly spacing.
If I drop the main assembly do I need to mark the pinion shaft to keep it the same and mark the axles to keep them the same?
