Old 11-25-2011, 12:40 PM
Default Spec on rear housing for torque
davids2toys 42-50 pounds to the extendsion housing to case bolts. If bolts are new and have washers I would goto 45 ft. pounds of torque. older bolts would goto about the same. 50 sounds a little high to me even if the case is iron. I would also lock-tite the bolts with a low tension. Not sure if any of the holes have liquid holes but add teflon sealer to those bolts with same tork. Good luck. Rick L.
