Old 11-29-2011, 01:03 AM
boblyon1's Avatar
boblyon1 boblyon1 is offline
Cobra Make, Engine: SPF #633, 351w stroker, Tremec 3550
Default Distributor Gear Wear
Matt - just an aside to this thread. I have a 351W stroker in my 633 SPF and learned the hard way that the distributor gear tends to wear if you have a high performance oil pump. I didn't catch it in time and ruined the crank and had to re-build the engine. Good idea to check the distributor gear wear every now and then. My mechanic says the 351W is famous for this problem.
Bob
"All that is necessary for the triumph of evil is that good men do nothing" - Edmund Burke
