Old 11-29-2011, 10:30 AM
patrickt patrickt is offline
Originally Posted by davids2toys View Post
With the rear, how much friction modifier should be added? I have an old 8oz unopened bottle of Amalie on the shelf, but i read somewhere this was not a good choice to use, but I forgot the reason why???
There's nothing wrong with Amalie -- it's good stuff. Here are the specifications for the Jag/Salisbury differentials that ERA uses (in both the Jag inboard and ERA outboard braked flavors):
The filler and drain plugs are ½” square. Fill to about ½” below the bottom of the hole with Moroso climbing gear lube, SAE 90, part number 34800, mixed with 4 to 8 oz. of Amalie limited slip additive (part # 505-6775). If the above are not available, you may use 80W-90 GL5 lubricant with an equivalent limited slip additive. If the limited slip seems to be sticking (ratcheting around sharp corners), drain add refill, replacing the Amalie additive with 2 tubes of GM additive 1052358.
