Old 11-30-2011, 06:33 AM
blykins blykins is offline
Originally Posted by westcott cobra View Post
I don't want to rev higher then 6K. What i want is a "bit" more HP and as much as torque i can get out of a 331.
The 349 i don't want to build because i really don't like the piston designs with small ring groove distances or open groove for the oil control ring in the pin area .
My MK IV has to be a cruiser with the ability to go a bit faster if needed It is a long nose body and looks very british with its green metallic paint, it will be a bit of cobra understatement with rear exhaust and small tires.
No track use, no strip, just going across the country to as much as possible cobra meetings with a smooth running healthy small block 5.0 with a bit more potential and a nice firing order.
The main cam specs of the 61010 Voodoo are:
Basic Operating RPM Range 1,600-5,600
Intake Duration at 050 inch Lift 211
Exhaust Duration at 050 inch Lift 219
Duration at 050 inch Lift 211 int./219 exh.
Advertised Intake Duration 262
Advertised Exhaust Duration 279
Advertised Duration 262 int./279 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.541 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.549 in.
Valve Lift with Factory Rocker Arm Ratio 0.541 int./0.549 exh.
Lobe Separation (degrees) 112
Must be enough to achieve 270 or so real rear wheel horses and close to 400 lb/feet.
No? Yes?
For carb size I have 600 cfm in mind. By "i don't know now" i meant the manufacturer. My last carb on the FE was a Quickfuel HR series vac secondary with e-choke.
Is there any other not too expensive carb available with screw in air bleeds you made good experiences with? (Never ever BG .....)
Westcott
I wouldn't let the oil rings get in the way of adding more stroke. It's a non-issue. A lot of guys say that, but if they knew how many 347's there were running around, it would change their minds. How much difference does .150" of stroke make? It can make a lot. Plus if you're making 1.4 hp/ci, another 20hp is quite a chunk.
With the cam that you listed, you probably won't be able to rev past 5000-5200. I would use a larger cam than that for a 302, much less for a 331. I would also limit the amount of split that is in the intake/exhaust durations. Eight degrees is too much in my opinion and this only adds to overlap and reversion. I like the 112° LSA, but I would limit the split to a single pattern cam for a street car. Of course this all depends on the cylinder head choice as well, as more flow will make a cam more efficient. The AFR 185 would be a great head for this combination.
It's hard to beat the Quick Fuel carbs and I would go with a 600-650 cfm carb as well.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
