Old 11-30-2011, 11:59 AM
Keithc8 Keithc8 is offline
Default 428FE Complete Engine 460ci. $10,995.00
This would be a great Engine for a Cobra or Mustang build. This engine will
be fresh of the dyno with most all new parts. This engine made 583hp/571trq.
428 block Bake,tumble,crackcheck & Fully machine
Stock 428 crankshaft offset ground 4.200 stroke
Scat 2-Icr67007/16 rods
Custom Diamond pistons & Plasma moly rings
clevite & Fed-Mog bearings
Pioneer SFI Damper
Comp Cams Custom Hyd.roller Camshaft
Morel Hyd.Roller lifters
Ford Racing Timing set
Stock front cover & pointer
Melling High Volume Oil pump
ARP oil pump drive
Moroso T-Style Oil Pan Pick up & Dip stick
Edelbrock CNC Ported Stage II Heads set up complete
T&D Race Series Rockers
Comp Cams Push Rods
ARP Head Bolts
Original Police Interceptor PI Intake Port matched to heads
MSD Dist & KCR Logo plug wires
KCR Logo finned valve covers
Fel-Pro Gaskets
Quick Fuel 780 carb
Bal.Blueprint & Assm.complete Dyno tested & Tuned
Please Call with any questions
870-246-7460
Keith C
