Old 11-30-2011, 01:14 PM
Keithc8 Keithc8 is offline
Default 306ci.Crate Engine $6495.00
For sale is a Ford 302 5.0L 306ci Crate Engine (400hp/375ft/lbs torque). This engine will be dyno tested and tuned with all dyno and build sheets. This would make a great addition to your Cobra project. Feel free to research us and check out the quality of work. We pay very close attention to detail and this engine will be no execption. The followong parts will be included in the crate engine:
- Fully machined Ford 302 Roller Block (baked, tumbled, crack checked, tapped, deck height blueprinted, bored and honed with torque plated, line honed, lifter bores honed, new cam bearings and freeze plugs installed, painted black and prepped)
- Eagle Cast Steel 3.000" Crankshaft
- Eagle I-Beam 5.090" Rods
- JE Flat -Top Pistons 4.030"
- Mahle Plasma Rings
- Federal Mogul Bearings
- Balanced to 50oz
- Ford Racing E303 Hyd Roller Camshaft
- Ford Racing Hyd Roller Lifters
- Comp Cams Hardened Pushrods
- Federal Mogul Timing Set
- Melling HV Oil Pump
- Ford Racing Stock Style Front or Rear Sump Pan Powdercoated Black
- Stock Front Cover
- BHJ Damper
- Edelbrock E-Street Aluminum Cylinder Heads
- Scorpion Aluminum Roller Rockers
- Black Powdercoat KC Logo Valve Covers
- Ford Racing Plug Wires
- MSD Billet Distributor
- Ford Racing or Edelbrock Aluminum Waterpump
- Quick Fuel HR-680 Carburetor
- Engine will be balanced, blueprinted, assembled, and dyno tested.
Feel free to call with any questions.
870-246-7460
Keith C
