Thread: Oil Temp Probe
Old 11-30-2011, 06:33 PM
ERA Chas ERA Chas is offline
Paul, as a test, I would: plug your current sensor location, drain oil into a clean pan, install the sensor (probably need an adapter-I forget the thread sizes) into the drain hole. Refill oil. That will tell you quickly if you're getting real temps up there.
FWIW, I fill mine with seven too and the cooler, filter and lines account for 1 1/2 more.
Chas.
