Thread: Diy
Old 11-30-2011, 08:53 PM
Lightingrod's Avatar
Lightingrod Lightingrod is offline
Cobra Make, Engine: Classic 427, I purchased it May 2005, the kit was bought in 1991. I'm not sure when it was completed! Installed GMPP Connect & Cruise 376/525 with T-56 S/M 3.55 gears about 2 years ago! 1/4 miles is with old setup!
Originally Posted by tcrist View Post
Al,
The ones that I have seen that slide on have small brackets welded to each side and then have a spring between the brackets pulling the two together. Other wise you might get exhaust leaks between the two.
We went ahead and welded the tubes to the collectors. So what you see in the photos above is now one piece. We are also going to weld the 3 1/2" taperer reducer to the collector. I'm thinking of then using a V-band clamp between the reducer and muffler!
Dynatech 794-91230 - Dynatech V-Clamp Kits - Overview - SummitRacing.com
I'll get some photos tomorrow!
Al
I want to do right, Just not right NOW!
